EPS = Expanded Poly Styrene
XPS = Extruded Poly Styrene
Both are rated for underslab use unless the particular prodcut is labeled as NOT for underslab use. Lot of bogus wife's tales that you must use one or the other. Since EPS is so much cheaper people assume it must not be as good and for certain applications, I prefer XPS. Underslab insulation, due to cost, EPS is superior.
