Fold UP (not DOWN) workbench ideas, please.
mad german
Fenton, MO
Hi all,
I'm looking for some ideas for a folding workbench (attached to a wall) that you need to fold UP to use. I've seen many that are fold DOWN, but I have built in shelves above the area I'm wanting my workbench, so I need something that "hangs down" when not in use.
I'd like to see not just the top of your bench, but how you have it attached to the wall, what the support structure looks like, and how the legs of the bench are attached (if they're folding) or how you attach them when the bench is raised up.
Thanks in advance for all who can help!
Zeke
If you want support at the back you can attach a ledger and move the hinges down on the bottom of the work surface just shy of the width of the ledger. When you fold up the back edge will slip over the ledger. You will have to round it some. So now you just need single front legs, not stands. Best would be to have something separate rather than hinging from the bottom. They would need to be latched before you could lower the table. Or have them on the extreme ends so that they fold up as you let the table down. Those would have to swing 180º to work.
Angle iron on the front for anti bowing.
I like your idea, Sounds like it will be next to a car.
gleman
Michigan And Florida too!
The several times I've toyed around with that same idea I came up with too many compromises for what I wanted.
What are the requirements for your bench?
Light usage, or do you need a sturdy surface for heavier things?
mad german
Fenton, MO
Hi there. My usage won't be heavy, i.e. rebuilding an engine. It'll basically a "heavy duty DIY home workbench." Some motorcycle work, small appliance repairs, etc. I have a feeling that my heavy use is the same as many of you guys' light usage, lol. I definitely respect the craftsmen here.
N_Jay
My S-I-L's house has some in the garage.
Simple design with a 4' x 4' top surface built with 2x4 edges.
Attached with door hinges to a ledger board lagged into the well studs.
Feet are 2X4 on bolts to pivot when you lower the table top and a second hole for a lock pin.
You pull the pin and the legs swing inside the sides edges of the table as you raise it.
drwheels
okla. city ok
I used a solid core commercial door and steel door frame to make a fold up table for my planer. You could flip it over and it would fold down.
NUTTSGT
Northern Central Ohio
You have to re-read the OP's post. "Fold" is confusing. He wants it to drop down like a drop leaf table. He stated cabinets above.
Well, actually in his original post, I take it differently. To me....
Fold up, ... bench top is stored at eye level.
Fold down..... Bench top is is stored at knee level.
If he can post a picture of what we're working with, it would help.
EDIT:. Now I have reread it 3 more times,. I caught the "to use" part. It is confusing.
Either way, point of view.... it's going to fold up and down.
Stuart in MN
Minneapolis
I built my first workbench in my old garage similar to this, and it worked pretty well. The work surface was 4 feet wide by 2 feet deep, made from 2x4s. It was fastened to the wall with heavy duty hinges. At the front, two more lengths of 2x4 were fastened with two more hinges to make uprights, and they angled back so they wedged against intersection where the wall met the floor. I ground the heads off the hinge pins so they were removable. When the bench wasn't in use it hung down flat against the wall, and the two uprights were just laid on the floor. I'd lift up the bench, put the uprights back in position, and put the hinge pins back in place. It was very stable, the more weight you put on the bench top the more the front uprights wedged against the base of the wall.
mogandave
Bangkok
Right-triangle plywood on gravity-hinges for the supports.
Plywood rectangle on piano hinge that folds down and hides the supports when down.
You pick up the table the triangular-supports fold out with the gravity-hinges. You push the supports in and let the bench down to store.
Jayman17
Seattle, Wa
I built this, I think this is exactly what you're looking for?
Thanks for posting this video. I posted on your thread asking for details of construction. When I read this thread I thought of your workbench but had forgotten the thread where I had seen it.
That is a really nice design and execution.
Jay
ItsNemo
Canada
Jay
Thanks Jay! It worked out really well for me, use it all the time for metal working projects instead of my main wood bench :)
Link to thread for those looking for it:
arrowhead
Stillwater, NY
I've saved this picture because I thought the use of the folding legs is ingenious. Obviously not for any heavy work, just a work surface.
Hey that's mine! I'm shocked and honored that someone posted some of my recycle handiwork haha. It's still in use today and gets quite a workout. And it gets folded up frequently to make extra room when needed.
whateg01
doo dah, kansas, usa
I would have thought the cabinets above would pretty well define which way it has to move. 🤷‍♂️
Greenlawnracing
Edmond, OK
I built this from plans I saw online using a piano hing and some scrap wood. It’s a PITA. After seeing the Amazon brackets, I’m gonna take it down and build a better one. I was overwhelmed with the bracket options. The original link is sold out of the 18s.
Same challenge as you - no space and fold down due to the cabinets. I use a Worx 051 almost daily, but could use more room and also prefer something higher for some jobs.
Poolshark314
MD
Just search for "18 inch folding shelf bracket" if you want 18", and then pick a set based on your weight requirements and color preference
ItsNemo
Canada
Desktop is 42" x 42"
Brackets are 24" and good for 500Lb. Not that I would test it...
I'm using it as a WFH desk, nothing heavy. If I do want to put weight on it, I'll add a support leg of some sort.
These are full size 24" x 36" prints:
I guess that's the difference with what I did, the fold out legs means it holds oodles of weight...I've stood on top of mine plenty of times and you don't feel ANY movement in it. I'm fairly sure it could hold 1000lbs easily.
Greenlawnracing
Edmond, OK
Do you feel any give when you lean on the end of it?
I was thinking of making a workbench 36 - 40 inches deep with a similar size bracket.
Apologize to threadjack, but I've been inspired!
Trapps
The Detroit Zoo
It's very solid, no wiggle, no sag. (more instal details in this post) It has not seen any heavy weight though, maybe 50Lbs. in addition to the weight of the top (which is considerable). I think you'd be safe with a 36" deep top on the 24' brackets. Just be sure and use appropriate fasteners to the wall and to whatever your top material is.
:beer:
mad german
Fenton, MO
Thank you, thank you, thank you for all of your replies. I stumbled upon these brackets and I like them. However, it says max table width is 40”.
If I buy two sets (to make a wider table) releasing all 4 might be a problem since the release tabs are recessed. Any ideas on how I can release all 4 at once?
rsparks64
Hill Country Texas
I don't have any good ideas about releasing all at once except possibly running some kind of cord from each that when pulled will do the release and bringing all cords together and binding them so one pull could do the trick for all brackets. Also, depending on what size table top you are using, those brackets can be placed up to 32 inches apart, so doing only 3 brackets would give you a span of 64 inches just for the brackets and I imagine you could extend the top a bit a have something at least 6 feet or so. Using 3 brackets might make it easier to release all at once.
ItsNemo
Canada
Just do two separate benches side by side and make sure they're mounted equal.
whateg01
I don't care what it says the maximum width is, if the capacity is sufficient I would make it as big as I want. I would think the maximum width it more likely to be how far out from the wall the shelf hangs, just from a leverage perspective.
ItsNemo
Canada
It will eventually start to sag in the middle and the force will become horizontal on the brackets as the sag pulls them inwards.
Now why didn’t I think of that?! Great idea.
