rob in nh
Hi guys, I was wondering if anyone has build a workbench that folds down when not needed. If you have any idea's that would be helpful. thanks
Definitely not enough information for anyone to offer much useful perspective. Based on what's been provided so far, the best answer I can think of is Google "fold down workbench" or "fold down workbench plans." You will get lots of results from miniature prefab tables to massive steel work benches.
Here are some of the factors to consider:
- Intended use (how heavy duty does it need to be)
- What support is needed when it's down?
- How heavy do the hinges at the rear need to be?
- What type of support on the front?
- Legs undeneath?
- Should they permanently attach, perhaps folding legs like a fold up table?
- Should they be massive piers that are set in place?
- Can you support it from the sides and avoid front legs altogether? Something like a 2X that it comes down and rests on.
- Is it in a cove that works for supports on the side walls?
- Would this give it enough support or is the cove long enough that it can't reasonably support the entire length?
- Cables, chains or some type of folding bracket from the back wall?
- Will said supports be in the way based on the intended use?
- What type of top makes sense?
- Smooth lightweight for delicate work
- Thicker and heavier for more substantial work
- Available space
- How much space is available when it's folded down
- How much space is available when it's folded up (how far can it stick out and not be "in the way")
- What obstructions, if any are there to work around
- Ease of deployment
- Will it be long enough and heavy enough that one person can't lower it by hand? Does it need to be lowered by some sort of powered mechanism like a manual or powered wench?
- What are the consequences if the person lowering it drops it?
- Is it safe for the person operating it?
- Is noise a factor?
- Is potential damage to the bench and it's surroundings a factor?
- Cost
- Is this a show piece or a work piece?
- Are you on a limited budget
- Which is more important: safety, aesthetics, functionality, or cost? Not to say you can't have everything, but each element affects the other and you must decide the proper balance.
