Food grade hacksaw blades
Ak Jim
Interior AK
I’m trying to find some food grade hacksaw blades to cut frozen meat and fish. I’ve seen where I can buy a butcher saw but would rather just get a blade for my existing hacksaw. I really don’t want to buy a saw that would only be used a few times a year.
Jacobs976
Indiana
The local butcher just uses a sawzall with Diablo blades. Apparently they go through bone like it's nothing.
Edit: DeWalt sawzall.
RivennHewn
PNW
I just cut up a frozen salmon with a diablo.
Tasted great!
Buy it by the roll, cut to length? Or a 25” and make two? I do that to repurpose butcher saws as big hacksaws. Mine have pins vs holes, and about 5-1/2” under the frame. I can punch holes and put tension pins in them
Your food grade should be a stainless blade, just for general sanitary reasons.
merkyworks
Texas
SS is used for corrosion resistance which is a sanitary concern, however if care is taken a CS blade is just as sanitary.
tamaraw
For occasional personal use, a lot of stuff could probably work as long as it is reasonably clean and doesn't flake paint or chips into your meal. I have used my milwaukee bandsaw to chop young coconuts in half once or twice.
For professional/commercial use (or even frequent personal use), you need a dedicated tool with a handle and blade made of easily cleanable certified food-safe materials.
so my 100 yr old carbon steel knife is not suitable to use any more?
how so?
If you can’t take care of it, you should box it up and send it to me, where I will give it special place where it is protected from family members who don’t know to wash it carefully after every use, dry it carefully, and put it back in a safe location again afterwards. ;) It will get used when they can’t see me using a wickedly sharp knife with abandon. But I don’t think any of mine are 100 yrs old, maybe 75 at best.
Most modern facilities use SS due to its ease of cleaning, corrosion resistance, ability to stand up to biocides, etc. I think the FDA would have a fit if they walked into a food processing facility and found carbon steel in use on anything food contacting, much less a saw blade, with all its nooks for spores to hide.
I once took some regular tools into a clean facility, and had to spray them down (Sporklenz) on my way in. By the time I got gowned, maybe 7 minutes later, they all had rust spots on them. They didn’t come back in for a long time.
A
Ak Jim
Interior AK
I think I could easily make those saw blades work in my hacksaw. Thx for the info from all of you posters.
