Falcon67
As a long time computer guy, I've known about the Jargon file for ages. I ran across a reference today and noted that this particular explanation of strange behavior could be applied in places other than computers. If confronted with a query about a strange electrical issue and you have no ready explanation, maybe this
fat electrons: n. Old-time hacker David Cargill's theory on the causation of computer glitches. Your typical electric utility draws its line current out of the big generators with a pair of coil taps located near the top of the dynamo. When the normal tap brushes get dirty, they take them off line to clean them up, and use special auxiliary taps on the bottom of the coil. Now, this is a problem, because when they do that they get not ordinary or ‘thin’ electrons, but the fat'n'sloppy electrons that are heavier and so settle to the bottom of the generator. These flow down ordinary wires just fine, but when they have to turn a sharp corner (as in an integrated-circuit via), they're apt to get stuck. This is what causes computer glitches.
