...for those thinking of tiles..... + + +
galwaytt
Galway, Ireland
....I've had garages before, and over 20 years, tried to make them better. Failed miserably, most of the time, and unless you're starting with a new floor, epoxy's etc don't always work, or, painted systems need renewing.
Basically, I coudn't find the time/heart to redo them, later, so they degenerated.........I found painted floors took tyre marks from hot tyres, and when wet, well, not the most surefooted or safe.
Of course that's the problem around here.........it's wet most of the time!
So, in our new house, in our 20 x 16 parking garage, I vowed to do something different. I noticed some of the car showrooms and workshops had tiles. Most workshops with tiles had 6" square, teracotta red. Which I didn't want btw.
In the end, about 6 mths after getting into the house, I came across the perfect one: Porcelain non slip, 12" x 12", rated for H-D use. Got them as a job lot from a tile shop for about €300 iirc..........and got the tiler to put them down f.o.c. as a 'thank you' for the rest of the house (most, tiled, everywhere)
I was concerned it'd crack at the edge as tyres rolled up.........nope, doesn't. I was concerned it'd be slippy when wet......nope, not really, although I did lock the front wheel of the RK one evening not thinking....
I was really concerned about using trolley jacks, etc. Nope, complete false alarm. Now, I don't go making a point of testing it with violence/4lb hammers, but so far it has more than exceeded my expectations......and it's great for cleanliness, keeping dusty footprints out of the house.
Moral? should have done it years ago !!
Oh: and one tip: I had tiles cut in half and used as a skirting tile too: tough, spill-and stain proof, and cheap !
Anyhoo, here's the finished article.........one w/toys :)
JD in DFW
Dallas/Fort Worth
Really nice work. Many of the new Mercedes dealerships here in Texas are putting in a tile called clinker tile out of Germany, they even fly the guy out and his crew to do all the installs. the stuff looks incredible like yours and really holds up well. We have even put 2-post lifts on top of this stuff and it hold up very well.
Great look, I would love to border or incorporate a like tile into some of my jobs sometime.
Enjoy your garage!
rwhite692
Central Valley, CA
Looks great. I really like the idea of using tile. At the Penske race shop in Mooresville, the whole place is tiled. When one breaks, which is not often, they just replace them. If I was to do my garage with tile I'd probably go with a 1/8" grout separation so that rolling heavy stuff around on it will be easier.
TONE
Question regarding the grout............
Is it sealed or something? I mean what prevents it from getting stained from contaminants that are normally found in a garage.
7echo
coastal Georgia
You can use a darker grout that will hide the stains. Or, better, an epoxy grout. Spectralock is one option.
thegarageguy
Porcelain tiles are great, the only weak point is the grout. It will still stain, trap dirt and eventually crumble.
rwhite692
Central Valley, CA
Staining I can see, and "trapping" dirt, yes, I suppose, on some level that is true...But, what's going to make it "crumble"?
It would make sense to use a very dark gray grout, narrow (1/8") grout lines, and to seal the grout.
G
galwaytt
Galway, Ireland
....tbh, not sure what grout the tiler used, but one thing I have learned: a too-small gap for grout is more likely to lead to issues, rather than a large one.
True, it can stain a bit, but at the same time: it's a garage...........! The lighter colour of the tiles makes the place always look clean, irrespective of the odd bit of grout dirt, and besides..........it can always be re-grouted in a few years.
Still beats the pants of a painted floor imho, although I admit our climate is a key factor.......
TONE
+1 on what galwaytt's comment about small tile grout lines.
swgray
maryland
Well grout can be replaced. Not fun, I've just did it the last couple weeks. What seemed quick, easy and cheap. Wasn't.
Kitchen remodel. Discolored grout and one chipped tile. No problem as I have extra tiles. I figured since I had as much leftover grout from the origional tiling (15 years ago) as I had used then, no problem. I'll just remove the offending grout, except where it will be covered by cabinets. The only cost should be a bag of mortar. Wrong.
$99 for new tool, Dremel Multi-max. Three grout cutting blades. $35 each. Better than 15 hours crawling, laying and moving about the floor while cutting it out. $95 for a new shopvac because the other can't handle the powdered grout. $18 for an extra 10 lb box of grout in a different color because the origional is no longer available and is needed because I came up short about 5 sq feet.
In the end, because of mismatched grout I ended up using some Nu-Grout in the color that closely matches my origional grout. And looks great. $52 for 2 bottles and shipping. I could have saved a lot of time and money using it in the first place. If I ever have another oppourtunity to repair tiles or grout, I will only replace grout as necessary and use that stuff.
And I still have to wait two more weeks for my countertops and sink.
thegarageguy
Not all of us live in sunny California. Snow, salt and extreme fluctuations of weather help deteriorate grout fairly easily. Our north east concrete takes much more abuse than you might be used to or aware of.
I completely agree! This is why we do not paint floors. We also do not apply epoxies and polyaspartics thinly like paint. We apply poured flooring systems via notched trowels and or squeegees. Big difference!
