Foredom Rotary
56Chevy
Looking at buying a Foredom Rotary Flex shaft. Looking to grind off tack weld on exhaust muffler where a die grinder is to large to access. Will this tool work? I could later use it for polishing, deburring etc.
56Chevy
didn't see an FH model. This is the one I was considering
M.TXBH Bench Motor with Square Drive
bczygan
DETROIT! Arsenal of Scrappers
Does harbor freight still sell the foredom knock off?
Haven't seen one in years.
Sent from my LGLS676 using Tapatalk
Yes. Bought one for the wife's jewelry making.
$50 less coupon.
https://www.harborfreight.com/flexible-shaft-grinder-and-carver-40432.html
Bill
txvwnut
Bedford, Texas
I’ve been using one for porting and polishing heads for over 25 years so I figure you could grind a tack weld with it.
engineer2
Chicago burbs
I recently got a Foredom TX with the 44T hand piece and foot control for Xmas. Nice unit. Used it Xmas day to convert an iPhone 7 case to fit an iPhone 6, lol. I like it a lot. I considered the Chinese imitations, but chose Foredom based on the better reviews, range of accessories, and parts availability.
CR888
There is knockoff Foredoms on EBay that are replicas ie true copies with the Foredom logo etc. I have a more powerful 1/2 hp Mastercarver but they cost more than a genuine Foredom. I've heard from guys directly that the fakes or even HF cheaper ones are not bad at all.
Git
S Cal
seber
Deep East Tx.
I make jewelry and cut stone with a Foredom. I started with a cheap knockoff and it went to **** pretty quick. I've also tried Dremel types and have been totally disappointed both with power and toughness.
Thedave1164
This is the model and hand piece I have
Well made and likely to be something my wife will sell off cheap in the garage sale when I croak.
pcmeiners
"I have a more powerful 1/2 hp Mastercarver but they cost more than a genuine Foredom."
Both the Foredom TX 1/3hp model and the 1/2 hp Mastercarver use the same wattage (same horsepower ), Foredom uses a more realistic horsepower designation. Foredom runs at 15k rpm, Mastercarver run higher at 30k rpm. The Mastercarver has a reverse switch setting, the TX does not (but the TX could be modified). Foredom is a standard flex shaft, Mastercarver is not. Priced basically the same.
From what I gathered, few ever use a reverse motor direction feature, anything over 18k rpm causes premature excess wear, though it would be nice to have for occasional use. Foredom has large number of accessories/hand pieces, not including all the sanding , grinding, cutting accessories common to both. Foredom's TXH square shaft (older model) is more suited for mechanical shop use, as the square shaft is rated twice as strong as the keyed shaft on the newer TX model; trade off is the older model has far less hand pieces to chose from.
Basically a draw a to quality, power, price. Foredom ahead as to accessories.
joe_pinehill1
Northern Virginia
I have a 1/3 hp Foredom and an M12 Milwaukee rotary tool. Since I got the Milwaukee the Foredom does not get a lot of use. With good quality carbide grinders from McMaster, either works very well.
Also, if I were to buy another Foredom, I would go with the 1/4 hp to get the forward / reverse feature. Maybe they have changed but I bought mine, the 1/3 hp did not offer this feature.
pcmeiners
Just purchased a second Foredom….
Just purchased a SR version off Ebay, supposedly a clone for under $100. I highly doubt it is a clone, I think it is the real thing, past its patent period, and the Chinese manufacturer supplies Foredom , but does not care if they cut into Foredom's >$225 profit margin by selling on Ebay .
"Maybe they have changed but I bought mine, the 1/3 hp did not offer this feature. "
Foredom still does not, but the 1/3hp could be modified in a couple hours, I will eventually modify it.
senlow
Wheat Ridge, Colorado
What sort of work do you do with your die grinders? It seems to me that the Milwaukee is kind of big, heavy and clunky. Of course, it's more portable than a Foredom. I would expect to use the Milwaukee for heavier duty work that can't be brought to the bench.
I prefer the smallest and lightest tool that will do the job well. I still use pneumatic die grinders. My pencil grinder is about the size of a Foredom handpiece and the hose I use is more flexible than the Foredom cable. My full size die grinders are more compact than the Milwaukee. Of course, I still have to deal with an air hose.
OP - I apologize for a bit off topic. I'm sure a Foredom will work for your application.
PittsburghTim
Being able to reverse the motor is a very nice feature to have if sanding or woodcarving as it allows you to somewhat direct the stream of material being removed. This is especially useful if being used with a dust collector.
