Forklift Ideas
HzEmall
Surrey, BC Canada
Post your pictures of different things and different attachments you have made for your forklifts to use them for things other then lifting pallets etc.
Wanted to figure out a way to use mine for moving my trailer in and out of the shop each day so it's secured at night.
Anything else you use them for?
930dreamer
Amarillo,TX and Stinnett,TX
Re: Forklift Idea's
I have an industrial storage rack with a lift base, it has three side with rails and I use it for changing lights bulbs, installing ceiling fan etc. Some forks have a hole for a trailer ball.
bimmer1980
York, PA
I built a spreader beam from two pieces of angle iron. I used the spreader on my forklift for lifting and setting all of my 28' attic trusses for my garage.
I also used it for lifting and setting the various dormer walls and gable end walls.
The forklift is one of my best purchases..... :beer:
H
HzEmall
Surrey, BC Canada
what kind of trailer?
i grew-up with a forklift, it had holes in end of the fork prongs to simple hand-tighten a 2" ball through it.. we moved things for over 30 years with the forks, the holes never made a weakspot in the fork. (the holse were torched-in to the fork).
Today, I cannot say what the dimensions were on those forks, though.
Just a 20' flat deck trailer
Joe69
Muncie, Indiana
Here's a pic of the hitch I made for the forks on my baby Bobcat. We have a similar hitch on our John Deere 482 forklift at work. We use it to move trailers, and it can be used for lifting. A hole through a fork, and the rectangular tubing allows a pin to be dropped in for quick and easy attachment. I can install and remove it in seconds.
Joe
bobadame
Here's a Big Joe in the back of my old Ford. The attachment is a Harbor Freight pickup bed hoist mounted to a reciever that slides onto the forks. Makes a handy little crane.
Bobf
Poway, CA
I have an old Toyota which only goes up 10' but it still comes in very handy. There is a hole in the right side fork where I bolt a ball for pulling trailers around (tear drop & and small utility)
I welded up some lg rectangular steel and some smaller stuff and made a small slip on crane for lifting stuff, such as taking a body off the frame, picking up rear ends, motors etc.
My latest is a small cage (32"X48") deck plate with 42" high railing I use to get me up 10' to use my long poles ( 10 -16')for tree trimming around the yard.
IndyGarage
Indy
Forklift is great for moving trailers - you can put them right where you want them.
I have a device I made - copied from a guy I bought one of my forklifts from; my forklift has 42 inch forks. I have a 42 inch long piece of channel steel that drops onto the top of one of the forks. I boxed the end of it so it can't lift off the tip of the fork and put a loop of 1/2 rebar on the other end which slides under the fork, so it won't tip off with a bunch of cantilever weight.
On the topside of the tip end, I welded a trailer hitch receiver - HF model with a pretty big step plate plus slots for the safety chains. I usually hood a small motorcycle strap through one of the safety chain hooks and run it back to the forklift load apron. I normally leave a 2 inch ball drawbar in it, but I also have a tow hook I can use as a cherry picker and a 2 5/16 ball if I need it.
I can slide it on the fork in about 10 seconds pull the strap tight, and run over and pick up a trailer and maneuver it wherever I want. I often use it to lift heavy objects in "cherry picker" mode. I recently bought a car hauler trailer which was rusty and I used this thing to pick one end of the trailer 6 feet off the ground so I could how rusty it was on the underside - (I did use safety jacks)
That thing is indispensable.
Bobf
Poway, CA
Here's some pix showing the two attachments I made for my little Toyota 2F13.
The small cage has two 5X2.5" rect welded on the bottom for the forks to slide thru, and a hole in the right fork lines up with the bottom plate to secure it in position.
