forklift rental
bcoke
Pawlet Vermont
Do not know if this belongs here but what should one expect to pay for a forklift rental only needed for an hour or so to move some machinery all less than 3500 lbs in shop.? thanks for any input or experience I am fully coca-cola hi-lo quantified to run one...........
nadogail
Coronado, CA
IMHO, the delivery and pickup charges will exceed the fees for using the forklift.
If you have someone, with a forklift, and close enough to you perhaps you could make an arrangement for them to assist you during their off time.
DeeKay
Colorado
everywhere I've rented around here is daily, weekly or monthly rates. None that I'm aware of are hourly. Around here $3-400 for a straight mast lift, a couple hundred more for a telehandler. Plus delivery charge which will depend on how far you are.
If you can get underneath your equipment and don't actually have to lift it you could save some money and just rent a pallet jack or a walkie stacker.
smaller local equipment rental outfits are usually cheaper than say United rentals or sunbelt but the equipment is usually pretty beat up.
Just give United or whoever a call, they'll be happy to get you a quote.
Wrench97
Southeastern Pa
Do you have a way to pick it up and take it back I.E. a rollback tow truck?
Highly dependant on your area and company relationships I paid $75 a day for solid tire 4,000lb off brand older lift if we picked up and delivered from the cheapest vender and $189 a day for a pneumatic tire 5,000lb Toyota. If you are using outside or on a rough floor get a pneumatic tire unit..
lis2323
It is unfair to assume this person's time is less valuable than a rental place.
I like to pay properly for services rendered just as I like to be properly reimbursed for what I do. JMHO
matt_i
The "construction rental" places have them, as others posted, there are pickup and delivery charges depending on how far they have to go from the home yard.
Its important to survey ahead on the terrain you intend to use it on. Concrete is no problem for cushion-tired forklifts, but go 1 inch off the pavement and it will sink into the earth up to the frame.
Also, I'm finding out that my asphalt driveway is marginal for cushion tired work. Great in the super hard drought of summer and frozen in winter but in the wetter seasons the base isn't up to the task and I keep making these sinkholes.
You will probably have to pay for a bottle of propane at their rates unless you arrange to return it full (just something to investigate and inquire about). There are also gasoline and diesel lifts as well as cushion tired versions. Make sure you have the proper fork length for what you are moving and that you understand the principle of counterbalance (moment balance)*
*....as I found out at work from a person who rented a 15k forklift to lift a 13k block of granite, and then was mad at me when I told them the day before that this won't work (!!!) When I finally saw the shipping manifest, the granite (crated) was 8ft wide x 15ft long, but the center of gravity of the crate being 48" out vs the 24" rating of the forklift meant we were wayyy undersized. To confirm I spoke to the people moving the machine and they were using a Versalift 40/60...(translated: at bare minimum a 40k forklift....)
Kaizen
New England
I also would be concerned if your driveway is not thick concrete. The delivery cost is a killer.
If you want more suggestions post what you are doing.
Renegade1LI
long island ny
You could rent a powered pallet jack or brick lift, comes with it's own trailer, if HD by you has it they do 4 hr rentals.
You can also get a walkie stacker for about 150 at UR or sunbelt.
Juiced06GTO
Sutton, MA
You are in a tough spot where you are in VT. The closest United to you is probably Albany, then Springfield, Ma, White River Junction, and then Wiliston. None are really that close to you and the delivery charges will far outweigh the machine rental. If you decide to rent from United, shoot me a PM and I will try to see if I can help out at all.
Bert_
NW Iowa
If you can find someone local that could just drive it over that would be simplest. If you have to have someone haul it that will be the biggest expense.
66cj225
NH
How about your machine being in the way of your construction material delivery?
PCustoms
VT
Browns in Londonderry has a rental guide with pricing and delivery costs.
Not sure on your access but they definitely have a few telehandler options.
APEowner
Sunny, New Mexico
When I've rented forklifts in the past they came with trailers and I did the pickup and delivery. I don't think you'll have to go that far but I know you can rent them in Glens Falls, NY.
bradpac
Central TX
If you're just moving stuff around in the one building, I would consider a manual pallet jack instead. you can buy one use for a couple hundred $ and just show it under a table and it's ready for the next time you need ot move something around the shop.
Walkers
Cave Creek Az
I rolled my lathe and milling machine into my shop using several pieces of 3/4” pipe and a Johnson bar. Fairly quick, easy, and cheap. So long as you are on paved or concrete areas it will work fine.
83VillageRepair
Merkel, Texas
If you have trouble renting a forklift locally you might look at a skid steer with forks they are more readily available. But if all you are doing is moving around sub 4k lb machinery within your shop I would buy a harbor freight pallet jack. I have one that is 5 years old and has been bullet proof. It moves my Monarch 10ee with ease. Another option is a Johnson bar and homemade equipment skates.
