NakeDiesel
I've been reading and reading on heat/air solutions for my shop and just can't seem to lock down on which way to go.
The shop is a 40x80 pole bard with 4" of spray foam on the walls and roof. I've carved out a room in a corner that's 8x14 for a commercial kitchen and another small room for a toilet area. Those will be insulated against the shop interior when I finish them. There are two insulated man doors, one for the shop and one for the kitchen. The kitchen has 2 windows the shop has 4 windows. and 3 12x12 insulated doors.
This past winter I was out in it about every day working on my race truck and all I used to heat the shop was two of those electric oil radiators. I only ran them while I was in the shop or would go out switch them on earlier so it would be warmer when I did go out to work. When I would need to paint, I'd fire up a propane burner heater for a short time to raise the temp quicker then shut it off.
Summer time it's bearable until it hits high 90's for prolonged periods but it's humid as hell inside the shop due to our high humidity in OK, so even though it's 70 in the shop your sweating while working.
My thoughts are to do a small mini split for the kitchen/bathroom that I can use to keep them above freezing in winter and cooler in summer while we are canning and other activities in the kitchen.
Then a 5 ton HVAC unit for the main shop with duct work running down along the wall or ceiling to direct the air across the shop. I don't think a mini split would work well out there. I heat the house with propane, but am thinking of just using electric in the shop do to some of the explosive fumes with some of the things I do out there like painting cars.
My big doors are rarely opened as most of what I do in there are long term projects that take weeks or months. I do occasional maintenance where vehicles are quickly in and out but that's not often.
Am I on the right track with these plans?
