Forward Lifts
Wilmington NC
I have been buying Forward lifts new since my business started and have seen many changes to their line up. Forward was bought from the family that originally start the company by Dover industries (owner of Rotary lifts) a number of years ago. One nice change was a one point release system, most other changes were to cut costs and cheapened the lifts or production process.
Just got into a new shop and called to order 3 DP10S2 lifts like the 3 I already have, and a DP15S for heavier jobs. Found out they don't make the DP10S Symmetric lifts any more and only make the DP10A with "versymmetric" arms. Those 3 stage arms are too flimsy for the diesel trucks I work on and the design puts the door of a truck right into the post, where as a Symmetric lift has 2 stage arms that are more sturdy and the door opens in front of the post. Even with ordering 3 lifts at a time Forward is not willing to work with me or my supplier to get me what I want - they will only sell me 3 DP10A2's then sell me the arms separately for about $1100 per lift. At that price I could step up to a heavier lift. That was actually their recommendation - step up to I12 lifts, "working on something so heavy you should be using the I12". These trucks typically weigh 6,500 to 8,000 lbs and they are basically telling me that their 10,000 lb lifts are no longer built strong enough to lift that kind of weight, especially since they know I am buying a 15,000 lb lift for anything that is heavier than usual. Guess that's what happens when a corporation decides "If you can't beat them, buy them" and buys out their competition then cheapens the quality that had them beating you - sending products and jobs overseas in the process.
Unless I find a Forward distributor with older symmetric models in stock it looks like I will be switching to Whip lifts that are still American made by the people who sold Forward to Dover. Only downfall is I will have to modify the adapters since they are not stackable like I need them to be.
dlcwent
Member Emeritus
coastal maine
Thanks for that info Diesel Addiction. I'm currently looking to buy a 14k 4 poster. I'm trying to make a smart decision. I was considering a Forward.
D
Wilmington NC
I have looked at a lot of brands of lifts in person and Forward is still one of my top choices. I may have found a supplier with the older arms in stock that is willing to work with me. I need to call him back next week and try to work something out.
todd8541
I am looking at buying a lift and was wondering what companies are american made. Also If mechanics here could give me some recommendations as to which type would be best. A 4 post you can drive on, a two post or something like this. http://www.eagleequip.com/product/PMR-6000-48.html. I would like something for general maintenance, oil change etc but also to do repairs front susupension, trans swaps etc.
I was thinking with a four post I could either purchase or make pick up points to place on the tire ramps (whatever you call them) to pick the vehicle off ramp so I can do suspension work or brake work. This is a home garage and not a professional mechanics shop.
Any feedback is appreaciated.
Thanks
Todd
D
Wilmington NC
I personally don't care for 4 post. Even when they are empty that take up space bigger than a vehicle. I feel that the lift would also get in my way for 90% of what I do under vehicles. A 2 post only takes up the space of the vehicle on it, or when empty only has 2 posts and leaves most of the floor space free.
The scissor jack may be a good option for you, I have never owned one to give you any feedback on them though.
par54
Mass.
Thanks
Todd
I am also in the same boat.( Home repairs) I am considering the Eagle 4 post, with the same feeling that I can lift the frame etc with a bottle jack or something. A friend has one and it is easier to set up and install. He is happy with it. Another advantage is you can lift it up and pull another car under it. Some plus and minus, for sure.
D
Wilmington NC
I ended up not being able to get the older arms and talked to a few diesel guys with the newer style who said they would do just fine for me. I ended up pulling the trigger on 5 DP10A2s and a DP15S for in the new shop.
We have backed the bed of one truck under another on the lifts multiple times. My oldest lift has the extended cylinder option with an extra 7" of lift and I can pull one Chevy 2500 all the way under another on that lift
plugtown54
Iowa
Whats the difference between the DP-10, and the I-10? The spec sheets seem to be identical (?)
goodmandl63
IN
I have looked at this lift also. What I was told was the only difference was the pump for the I10a was less expensive and made in China.
