Two Stage Air compressor 175 psi - $450 (Fairfax)
This is a Sears two stage air compressor. The Furnas controller is set to start at 150 psi and shut off at 175 psi.
The Marathon motor operates at 230-240 volt, single phase. It draws 21 amps. 1750 rpm.
Operates on a 2 pole, 30 amp circuit breaker.
The assembly is Sears Model 102-17316 7/84. Serial # 951431.
The compressor is Model 335, serial # 951431
The compressor is 60" long, 44" high to the top of the air filter and 22" wide.
It sits on a base made of 4"x4" pressure treated lumber on lockable casters.
The base is 54" long, 9"high, 29" wide.
It is equipped with 25" of stranded #10 copper wire I used just to get it going.
It has a belt guard, just not shown. I do not have the sheet metal screws to secure it, but it doesn't look hard.
There are also two air separators and some miscellaneous fittings.
This is big, heavy and awkward.
You will need three other strong men to load this onto a low trailer.
I bought this for a car project that never materialized. Now I don't need it and don't have room for it.
Cash only.
