I'm in late stage planning of erecting 40' x 50' x 14' metal building in South Texas and want to learn how you guys went about accurately locating anchor bolts using templates secured on the foundation forms. The building is still under design so I don't have the specifications for the building anchor bolt pattern just yet but want to plan ahead on how to locate the anchors.
I was thinking about using a 100' steel tape and triangulating the measurements from template to template believing I can locate within 1/4" in all directions.
I'm an old machinist so I can fabricate the templates accurately using 3/4" plywood. I was planning on securing a 1 x 2 board under each template to hold the templates up off the finished poured concrete so concrete guys could smooth the underlying surface. I was planning to secure each anchor bolt to the plywood using nuts top and bottom with the bolts sticking up the correct engineered height and extending down into the concrete at least 8" with large thick washers down at the extended bolt heads. If I need survey equipment, then I guess I had best make other plans. I live in a rural area outside of Victoria so no permits are required.
Your comments and ideas would be appreciated.
