Applied the Foundation Armor L3000 concrete hardener/sealer and had sprayed on a little too much in some areas. As noted in their instructions, any spots that have "pooled" will dry as a white residue. An email to Foundation Armor suggested trying a 40 - 80 abrasive rotary grit brush and if that doesn't work to diamond grind with 100 grit then 200 grit.
I'm trying to avoid having to rent a floor maintainer and the diamond pads. Would normal sandpaper on a 5" random orbital work at all for light sanding to remove the white residue?
