atvkid4eva
I Have a 40x30 detached shop that has a cinderblock foundation And a concrete floor. You can see one layer of cinderblock and then the framing begins. I have fully insulated the walls with plans to add plywood once the prices come back down. The garage also has two overhead NG Dayton radiant heaters. They are vent free, which I know is known to cause moisture. When I bring the temperature up to about 55degrees or so, I notice the foundation cinderblock will turn a darker color as if it is holding moisture or sweating. Is this normal or is this due to a humidity issue caused by the heaters not being vented? This is only visible from inside the building, not from the outside. I also have two ceiling fans that run continuously to keep the air moving at all times. I would like to be able to set the thermostat and keep the barn a constant temperature throughout the winter, but I’m concerned that the vent free heaters will cause a moisture issue. Is there anything I can do to prevent the cinder blocks from sweating and to control the moisture in general? Can I add a vent to the building, or is my only option to replace the heaters with a vented version?
