joseywales
It might be too late to ask, but for the first time in my life a contractor has shown up and will take action within 24 hours!
I have a crack on our poured foundation wall. House is nearly 30 years old and the crack has been there since we moved in, 15 years. Probably sold to us that way. Anyway, it hasn't changed and does drip, especially after heavy rain, or during prolonged rain. Enough that we will soak several towels.
The crack is wider on the outside of the home - all downspouts, etc. are routed away from the home. We have an underground drain to help with neighboring water. The outside crack is positioned under an overhang, so it rarely gets "direct" water.
Anyway, I had all of the tools out and even chiseled a tiny piece, then stopped. One concern was, where will the water go, once I complete the repair. I get weird with foundations, but also never trusted waterproofing folks. I found a foundation repair company and they showed up the next day. Great guy to talk with and seemed to know everything, without being told. In fact, he told me several times how to do it and exactly what I would need to complete the job myself.
The crack is not structural, minor in nature, and inside a closet.
Within a couple hours, he sent me the estimate for approval, which included our municipal Parcel #, etc., so he'd already looked that up. once I approved it, he sent me his Certificate of Insurance. I know some of you have better luck, but I've never had a contractor move so quickly and provided these items, without being pestered. He is the owner and at the age where he does not complete the work.
His plan:
Inside: Cut out the crack in a V, use muriatic acid to wash the concrete. Mix the hydraulic cement with a bonding agent and NOT water. let dry for 4 hours, then coat with rubberized waterproofing paint, covering about 12 " in either direction of the crack.
Outside: dig down 12-18" below grade, expose the crack and repair similar to above, adding a damp proof application, then a water proofing membrane. Then back fill, etc. He's not overly concerned about this outside crack and the inside was minor as well. However, since the walls outside the closet have been dry-walled, he can't see where the water might try to go, so eliminating it from coming in can only help.
Questions:
1 - The container I bought offers two ways to open the crack, but says to NOT us a V. Any thoughts on that?
2 - He's doing all of this for just over $700. That's a lot, or not, depending on how you look at it. Once complete, he will certify that it is repaired correctly AND that it was not structural in nature. If I had done it myself, I sense issues with either selling the house, or dealing with an insurance company, should "my repair" fail. Add to that, the fact that I'm on vacation and already replacing toilets, dealing with the pool, etc., we thought it made sense to let the pros take this one on. Thoughts?
Thanks for reading!
His plan:
Questions:
Thanks for reading!
