Four Sided Open-End Wrench?
Tul
Cali
I have a 27mm flare nut on my car's EGR valve that connects it to the EGR pipe.
EGR issues are becoming a regular hassle on my Toyota. I have a Craftsman 27mm open-end wrench that works. However, I'd prefer something with four sides to reduce the risk of rounding off the nut (I use antiseize on the threads). Also, an open-end ratcheting wrench would be even better.
I enclosed photos of what I'm talking about, first being my current Craftsman open-end wrench, the second being what I'm looking for.
Can you recommend brands and sources?
Steiger9
The few open end ratcheting wrenches I have used seem to have less contact area with the fastener, not more.
T
Tul
Cali
Thanks, both of you.
$135 is a bit pricey for me.
Maybe a non-ratcheting, four-sided wrench is the way to go. I remember seeing Husky brand at Home Depot about a year ago, but not in 27mm
T
Tul
Cali
gatlibs
N/A
I thought that four sides meant that you wanted to be able to position an open wrench in four different ways. I don't think that the two sides of contact in an open ended wrench matter unless it is flare nut styled. Else, Wright Grip wrenches would be styled this way.
619DioFan
San Diego , Ca.
27mm 12 point flare nut crows foot ( if the slot is wide enough ) about 40.00 on amazon. sorry no link.
myself I would get a 12 dollar 27mm combo wrench from HD and cut a slot in the box end. plus you could bend it for better clearance.
sberry
Brethren, Michigan
Yes, cutting the slot works quite well. Can see an old WT Grant wrench laying on top this was done to. They were brutally tuff.
4xdog
Santa Fe, NM
That second image in the op is of those awful "quick action" open end wrenches, not a flare wrench. A worthless mod, IMO.
I'd simply make one by cutting a box end as first noted by 619DioFan above.
gatlibs
N/A
An oil pressure switch socket is 1&1/16" (2.988 mm).
Lisle makes 13200,13250,13900 which might be adaptable to your situation. I don't know that O2 sockets get that big in size. What model and year of a Toyota has a flare nut accessed E.G.R. Valve? I have been searching Toyota egr 27 mm flare nut with no luck.
