morpheusmac
I would like to rough in a 12' opening versus the 10 foot opening my shop has currently to prep for a garage door install.
I am not an engineer and would like someone with a little bit more experience with an opinion on it.
here are some images:
Currently it is a 10 foot span with a sliding door on the outside. I would like to widen the opening to add a roll up 12' garage door. Looks like I'll be cutting out over two feet of foundation on the right side there to make it work.
There is only enough room on the right for the 4x4 and an added 2x4 to support the header on the bottom plate. There will be a 2x6 jamb added too which would be supporting the header as well.
I was concerned with the gaps at both ends of the header and whether or not a single 4x4 and a 2x4 were enough to deal with the load since I will be removing the two 2x4's supporting the head to the left.
Can someone with a little experience lend a hand?
The rest of the shop:
Thanks,
Tom
Thanks,
Tom
