niceflipflop
Planning to install a pre-hung door in my circa-1950s detached 10x20 garage, but can't find any best practices for this type of application.
Pics of the interior and exterior, with planned door location:
https://imgur.com/a/3imm6
(Outline is just approximate. Likely not using either of those existing studs for the frame.)
The garage is built on a single-wythe brick foundation that extends ~2ft above grade. Slab floor. I'm planning on cutting the brick away for the opening, but unsure about a few things...
For one, should I leave that very bottom course that's barely poking up above the slab and let the door threshold sit directly on it? Or should I remove it and replace with some PT? I hope to one day lay down an insulated floor, so I'm thinking I should go ahead hang the door a bit high off the slab. So maybe leave that course AND shim with some PT?
Is the single wythe of brick a problem? I assume I'll have to add some interior support under the threshold.
Secondly, how should I stud this? Can I get away with the jack and king studs sitting on the existing sill? Or should I run them the full length of the door, calling for a wider cutout in the brick? I actually thought about leaving the kings on the sill and running the jacks down. But that just seems odd. Can jacks be longer than kings?
Cheers.
Cheers.
