what type of roof is on it??
scissor lift
thats pretty much a given. I am trying to find out how to get the height. Do I build a 12ft wall and another 8ft wall on top of it? Or?
I'd say because a 2x4 that is 20 foot long would be a slinky!
I would break it up into 2 8' sections, and a 4' section. That way, you will have fire stops, in case a fire should start at the ground floor area. If not, the 20' hight will act like a chimney, and possibly take out your roof before the fire department got there. The last 4' high section will be easy to handle. You will need some good ties to hold the wall to the sides also.
I was thinking 2x4 20ft tall would be pretty wobbly. The longest section of wall is 20, maybe 25ft before a corner. Maybe if I double up the top plate on the bottom wall, and use simpson straps to tie the top wall to the bottom one.
In NZ we ALWAYS use horizontal pieces betweem the studs. (nogs/dwangs)
Creates a very strong grid.
Put in every 30 inches in height. Doesn't the building code there require this?
It would be easiest with 2x6 x 20-ft with double top plate as you say and staggered blocking. I wouldn't split the wall into two and the simpson ties do nothing for rigidity. If you have room, build the wall on the deck and hoist up with some mules. You can even split the wall up into sections if you have limited room or mules - such that you will have sistered studs.
Pics show how I did it - height of studs are 18 feet 2x6 @ 8 OC. I used a lift to get it started and then manned diags to finish. Any sheathing you use will stop wobble.
the simpson ties I am talking about are 1-1/2" wide straps that are 3 feet (or something like that) long. They are used to strap the studs on the top wall to the studs on the bottom wall to get rid of the hinge effect.
I think metal studs will be out on this due to cost. There now may be a mezzanine built which would also get rid of my tall wall problem, just frame it like a house...
