xscorex
I read so many different ways to do this its making my head spin! New project is re-finishing a basement room. 2 walls are outside walls. 1 wall is underground at least the yard slopes from the top down to the bottom. The old owners had used liquid nails to put up foam board, then glued paneling onto that, and not very well either. There is moisture becuase the paneling warped all over the place. So how should I start? any DIY websites I can check out?
Here's what I was thinking.
glue foamboard to wall
frame it out, not sure what size framing to use 2x4 or something not as wide. then more insulation? then plastic vapor barrier over that, then the drywall.
should I paint the wall with drylock or some kind of sealer? what about the floor? Planning on doing bamboo engineered flooring. room is about 12 x 10, really small.
