framing question, can I put a door next to a wall?
jgorm
San Diego
Is it legal to put a door right next to a wall, or do I need a couple studs in between? Check out the picture of the proposed for location. It will have double 2x6 top plates, with double 2x12 rim joists running parallel to that wall.
CNGsaves
KS and OK
Since you're building INSIDE existing steel building, your wood walls are just cosmetic and you can do whatever the heck you want !! ;)
I'd have the door open outwards so not to lose space within the framed in section. However, it's really your call on what looks good and works for you. Good luck.
Cyberbear
California
I agree with what others have said, if it's not structural, do as you wish. You don't always have to ask permission to alter your private property, contrary to what we are told, dare to question authority.
RivennHewn
PNW
I usually have a min. of 3 studs from an adjacent wall.
This gives you the room for casing, and clearance for the door knob.
dirttracker18
Slate River, ON
I agree.
I also question why you are building your walls that way? The bottom plate should be laying flat not upright and be sure to use a barrier between it and the concrete to avoid wicking.
FordTruckWench
California
FYI, you need an extra 2x4 in the far left corner (2nd picture) of the wall that's already built. Without it, you won't have anything to nail the wallboard or whatever it is that you use to sheath the interior of the office.
little d
NW Oklahoma
As others have said, yes you can but no you dont want to, it's a PIA to trim out. If your trying to save space with the swing of the door, ya might look into "pocket doors", no loss of swing space,
D
Fyrme
Green country, Oklahoma
I thought this ^ was the whole reason doors were always framed off the wall 3". Unless it is a load wall, there really is no reason for a header beam.
On a side note, is that redwood 2x6's? I've never seen NEW pine or fir lumber that dark.
HoosierMark
Southeast IN
You know you can tell the difference between experience and rookies. I cannot count how many times I did things like put a door in a corner and then it was a PITA to frame it and put the trim on. Experience is the best teacher many times. OP listen to what these guys are telling you. It may not matter to you right now about trim or finish but down the road when plans change you will be glad you followed their comments. The pros have reasons they do little things like the space from the corner.
41ratrod
Springfield Mo.
The 2x4 on edge is not attach to the wall it is setting there he is building
another wall on the floor. After nailing it together he will stand it up.
Just look a little closer you see what I am talking about.
nfk
Kansas
I agree with the others. Put the extra studs in to space the door away from the wall. It will look better and be easier to finish.
APEowner
Sunny, New Mexico
As I recall you're planning on putting a second floor on top of this structure. If that's the case then you need a fully framed corner.
As others have pointed out trimming out a door that's up tight against the corner is problematic.
As FordTruckWrench pointed out you also need to consider what the wall sheathing is going to attach to on the ends of the walls.
LXCam
Dead on as are the other answers. You'll need to head that door out correctly which require at least two studs. You could pocket the header into the adjacent wall to save 1-1/2", but like has been said, you'll have a ***** of a time trimming it out. Or you could reverse the swing (outwards).
Btw guys, he's using the mez as a wood working area. So the entire assembly is load bearing.
alwaysFlOoReD
Airdrie, Alberta, Canada
If the walls are loadbearing I would look at sistering in some full length studs on the wall where it's been cut for the cable. A 2x4 attached to the original stud in an L shape should work.
wssix99
Chicago, IL
How about using a barn door? You don't have to deal with all the framing/casing issues and they fit really well in places where you want to have the door all the way up against a perpendicular wall.
The only downside is that the hardware is more expensive than a traditional door, but you could gain a lot of functionality.
J
jgorm
San Diego
Thanks for all the tips. Doing the trim on the inside was something I didn't think about. I will add 2 more studs to space the door out 3". The door wall will not be the main load bearing wall. The wall in the back, and the front wall (just the footer is there now) will carry all of the joists. Check out this picture with some crappy MS paint annotations.
