tonydanzah
i Have a craftsman that looks identical to the atlas and stanley
It's a hybrid of aluminum hub with nylon sleeve that I pressed onto it. It's not a solid wheel, as I think the aluminum part started out an ashtray or something similar. Total weight is about a pound or so. There's a very small crown on it, pretty much the same as a MT drive hub. Works well.
Yes, that thumbscrew does lock the the tensioner. As far as the rotating assembly, that's not a setscrew. The assembly has a split bore, and that is a bolt that pinches it to the motor end bell.
