Free Drafting Program wanted
southpier
anyone use Sketchup?
or another suggestion?
i just want an electronic pencil! no 3d or gizmos.
thanks
jmiller_2308
Shakopee, MN
I like sketchup but it is unfortunate that they no longer offer a free program to download to your computer. If you want it for free you need to use the web based version which works fine but seems to be a lot more of a hassle to me.
Keep in mind that whatever program you use you will likely have some ramp up time learning how to use it.
bdbecker
Iowa
This is my favorite:
If you've ever run AutoCAD, there won't be much of a learning curve - the two softwares are very similar.
ZX3ST
STL
I use the same. It's a bit like working with an old version of autocad. Perfect for home use.
Really wish autodesk would provide a solution for home users at a reasonable price. 2k a year is a level above bonkers for home use.
BearsFan315
Portsmouth, VA
AutoCAD guy here, and used to use free software at home (Draftsight) then they went to paid use. seems like most everyone hooks you and gets you in then wants $$, not many free ones out there anymore. especially simple 2d drawing. Looks like there are a few good suggestions.
vavet
Ashland, VA
I've used Sketchup. It's free and easy, but not terribly powerful when you get into small dimensions.
It's fine if you're trying to lay out where you toolbox, cars, and stationary power tools will go in your garage.
It's not OK if you're trying to design a 3D print with a sliding dovetail fit.
I have access to Solidworks through work and I can use it at home if I take my work laptop home.
Solidworks is pricey....but...they offer a deal for hobbyists. I think it's like $99/year. It's not necessarily intuitive, but once you get the hang of it, it's easy.
If I was using it once a week, I wouldn't think twice about the $99/year. If I'm using it once, then that's a much bigger concern.
If you just have a single project you need help with, DM me the details and I can probably help. Plenty of other people can too. I'm no expert. There are plenty of people within 20 feet of my desk who can put my Solidworks skills to shame, but I can handle the basics.
ArcReactorKC
Out in the county NE of KCMO
I strongly disagree, I make extremely complicated models with very tight tolerances using sketchup daily.
vavet
Ashland, VA
Maybe there's a setting to increase precision that I could not find. If you use it that frequently, you're certainly more proficient than I ever was and I will humbly retract my previous assertion.
ArcReactorKC
I have many many years of sketchup experience which at this point is hindering my movement to a better platform.
There is a 3d printing template available on the start splash which should default to a more precise preset.
Mainiac Mat
Maine
If you can get your hands on the install CD for an old version of AutoCAD you should be able to install it. AutoDesk doesn't support perpetual licenses any more, so when the software launches and it goes to their web site to activate, it should do so without any fuss.
RoninB4
Under My House
OP should really define size/scope of project. Even a simple project gets redefined more often than anyone wants to admit. What others have posted about "free" (offers the bait) only to become a paid subscription after you've become comfortable with it (setting the hook) must be aggravating, plenty of people on another board have felt the sting. Free software can also be very limiting in what it will do, that's why there are different tiers of the same program, inexpensive basic programs that leave you wishing for greater capability ("We have a professional package available sir"). Even the educational level programs have limits, some won't allow you to save the file or a large watermark will be splashed across any drawing you attempt to print.
When taking AutoCad classes, Dr. Ward called it an electronic pencil. Looking back, I don't find "2D only" to be that great of a designing tool. It can make a file for ongoing use, have a UDF library (can be created by any of the CAD programs) and allows a visual representation of an ongoing layout but if you're going to use it for more than one project or the project changes over time (additions, drawings for contractors, approval by governing body, etc.) I might suggest a budget in the $200 range to get better software.
Not advocating this but I purchased a seat of SolidWorks back in 2014, expecting to use it for commercial purposes. I have used this program for more projects around the house/garage than I care to count. I've used it for everything from widgets, tooling, vehicle repair/modifications, to full home remodeling projects. Even just the bill of materials (BOM) on a drawing file cuts down on the number of trips I have to make for building materials. If you regard it as just another tool then the money spent for a better tool seems trivial the more often it's used. JMO/JME.
RoninB4
Under My House
-It shouldn't be too difficult to mount the learning curve to a better platform if you have years of experience. I encourage you to add to your skill set. Learning parametric 3D opened a lot of doors for me for the last 23 years. I was 45 when I started and I was just a machine shop donk. If I could learn it then I feel anyone can.
MikeC55
CT
I have used an old version of AutoCad for 2D stuff for years. At work I use NX, which has a great sketch tool. Too bad they don't release it as a stand alone, simple (cheap) version.
tool_scrounge
Southern California
98% of the time I use Solid Works. But sometimes I need to make a simple drawing or print life sized drill pattern templates. For that 2D work I use DeltaCAD ($20), it is really easy to learn and has dimensioning, etc. Sadly I see it is now discontinued.
BearsFan315
Portsmouth, VA
almost 30 years on Autodesk... from AutoCAD 12c2 to the most recent version. got all my Autodesk Certifications as well. started off doing customer drawings and layouts and then onto design, and into R&D !! in 2010 we transitioned into 3d and jumped into Inventor. we were doing 90% 2d and about 10% 3d. Then recently we transitioned that all new Products we do from day 1 are in 3d. truly fun to develop a new product from scratch and lay out everything. now we are 90%3d and 10% 2d. to make things even more fun about 3 years ago they (corporate) decided we were going to transition from Autodesk to DS Solidworks. which was fine for me as over the last 5 years in R&D working on projects and the company buying out smaller companies, i had Autodesk, Solidworks, ProE/Creo, and Siemens NX on my machine. along with Windchill PTC which was our document control, which i was in charge of and had to train everyone on. lot of work managing various CAD software's in a shared system, let alone trying to educate users how to use them :!:
best part of my job was that when we switched to SoliWorks i got to travel to get training on solidworks, so i would spend a week every other month at the training center. got to learn a lot and all the ins and outs of the software.
i spent months with each major player, evaluating their software and capabilites, mainly for 3d design. i sat with each company and presented them with a problem (component) and had them design it in 3d. then we went step by step on how why they did it a certain way, some did it multiple ways. i was very impressed with Creo team, they were top notch. really surprised we as a company did not go that route. we are doing complex compound designs for hydraulics !! impeller vanes, hydraulic volutes, etc... intense critical stuff.
needless to say i have used most of the professional 2d & 3d softwares out there. for 2d still partial to AutoCAD and realize that many of the freebies and newbies copy its layout and style, cant blame em.
