2mJps
I have wondered if a frig compresser could be used to recover the freon from cars or central air unites then would it be ok to reuse? Would it need to be or could it be filtered?
I know there are diffrent types. Can it be done on cars with 134a?
Thanks Guys if i was to ever do this it would be on my own stuff and i wouldnt reuse it if there was something that went wrong.
There used to be guide lines from the epa for home built recovery units, not sure if they are still around or if home built units were phased out.
It is against EPA regulations to use recovered refrigerant in any system other than the one it came from without it being recycled by a liscened recycler.
That's correctFrom what I remember, it's either back into the same system or it can be used in a different system owned by the same owner.
You can find used recovery machines for sale, especially for older refrigerants. If you pull used Freon from a used car for example, you really have no idea what is in it. It has to be distilled to separate out mixed refrigerants and contaminants.
A good read here: http://www.achrnews.com/articles/112079-road-to-reclaim-purity-is-a-complex-one
Only of you start with an evacuated recovery cylinder or of all of the refrigerant in the cylinder is the same type and from the same owner. If any other refrigerant is in there it must be recycled.
Tommy
You aren't supposed to mix types of refrigerant anyway, makes the recovered refrigerant useless and generally it has to be destroyed
