Freshening up oil and grease soaked workbench
TheClaw
Chicagoland
I picked up this Uline workbench off Marketplace. The top is solid except it's soaked with oil and grease. I've cleaned off workbenches before with bleach and a power washer and they've turned out okay. Wondering if there's any other ways to spruce this up without sanding it all the way through?
Yes, I thought about just flipping it over except all the holes are on the bottom. Yeah, I could put some wood putty in there and drill new holes on the other side, I was just hoping to see if I could salvage the topside.
MovingAlong
There's a layer to be removed: chemical stripper, pressure washer, hand planer, sanding...
I'd be tempted to plane it with something inexpensive like this:
*note, I've not actually done this myself, but have seen positive results from others.
geneg
Midwest
I don't think it looks that bad. I'd probably hit it with 100 grit random orbital. Wipe it down & give it boiled linseed oil to the point of refusal. Too much time & trouble to making it "new" just to use it as a workbench. The patched holes would bug me, so I wouldn't turn it over.
Use some Watco with color to blend the shades in lieu of the BLO.
geneg
Midwest
Another approach is to brush in some cheap finish. Let it dry/cure. Then use stripper to pull some of the color & oil out of the pores. You'll still need to sand some & apply some protection---BLO or Watco
oldmachinenut
Missing, presumed dead in central Pa.
BurtEggley
wipe it down with some solvent on a rag and let it dry. Then sand it and see how it looks. Staining it might help as some suggested. Then seal.
JohnX14
Boston 'burbs
How deep has the oil seeped? I've leave it as-is or flip it over. I don't know how you extract oil and stains that have soaked into hardwood. I'd rub more oil on it and call it character, depending on what my intended use was.
Higgins
Shepheardsville, KY
I got the same project ahead of me. The top is from a company that produced "Stuff" for the millitary in the 40.
Sold the old legs to a friend. Couldn't believe what the were worth!! Old guys were drooling over them....
I'm going to see how clean the top will clean up!
Actually the ole top looks looks neat! Has a lot of character! Will see how the surface looks after some sanding, and see how an oil finish looks!
T
TheClaw
Chicagoland
It's looking that way. I hit it with some 80 grit on a couple of test spots and I think it'll clean up pretty easily. Stay tuned
Torque&Recoil
NE Ohio
I have successfully used heat and K2R to pull oil out of old milsurp gun stocks. You heat the wood with a heat gun, then apply K2R. The oil gets absorbed by the powder in the K2R. Admittedly, it would take several cans to do a workbench.
FWIW:
The shelving in my garage was salvaged out of our old plant. It's all 2 x 4, 2 x 6, and 2 x 8 dimensional lumber. (NOT pressure treated.)
When we moved the plant to a different location, the owner said I could have the old shelving, but I had to tear it down myself on a Sunday and haul it all out.
I hauled it all home and stacked it up outside and let the rain fall on it for a few months.
The shelves had been used to hold engine cores, so they were well-soaked with engine blood and grease and gick. Mostly black.
I laid them all out flat in a neat row.
Then I boiled about 8 gallons of water, put that into my washtub, added about a pound of trisodium-phosphate and a gallon of bleach, and went at them with a wet mop. When I got them scrubbed down as best I could, I hosed them all off with a garden hose.
After drying for a couple weeks, I stained them with the darkest oil-based Olympic stain I could find.
They look great!
YMMV
BurtEggley
yes. When you are done I can come by and pick it up. Thanks for sanding it for me. Absolutely will look gorgeous in my garage. :)
You will be really happy with it.
NUTTSGT
Northern Central Ohio
Looks good...as crazy as it sounds, I was going to suggest staying away from trying to wash, power wash or an excessive amount of water.
I had several sections of tops like that. I took everything out of the garage to pour a new floor and had them stacked up outside beside the wood pile...we got rain I wasn't expecting while I was at work, I believe, and needless to say I was not happy.. Every one of them started to warp and split apart. I should have covered them but I failed to.
I was just starting the Garage Refurb and did not have time to spend hours on them...
abfish
Excellent results. That's why old school hardwood floors last so long; it doesn't take that much effort to bring them back.
