Friedrich thru the wall a/c
fortee9er
Houston, TX
I have a 3 car garage. It is fully spray foam insulated. I have a 24000 btu Friedrich thru the wall a/c. The unit was not working properly and I diagnosed it. The problem was the capacitors (it has 2). One to start it and a second one to keep it running. I removed the capacitors because I wanted to take them with me to the a/c supply store. While I removing the capacitors I though I was videoing it for when it came time to install the new ones. To my surprise the video shut off early.
I need to find out which wire goes to each post on the capacitors.
Here are the details:
Friedrich model numberSL24J30A-3
If anyone has any knowledge that can help please let me know. Summer is coming it the garage will get very hot.
Thank you
American Locomotive
Rhode Island
Almost every larger window AC I've ever taken apart has a little folded piece of paper stuffed somewhere inside of it with a wiring diagram, or has a wiring diagram affixed somewhere.
This seems to be a fairly comprehensive manual. Find your specific wiring diagram:
fitter30
Peace Valley,mo
Take a pic of the wiring diagram. Nothing comes up with that number
A 35 mfd + - 5 mfd would be the compressor
5-10 mfd fan motor
