Front Porch Post ?
karoc
Hemphill Tx
Guys this is for appearance only, not for structural.
Where I live now my front porch has 4x4 post, and they look like toothpicks. So this go round going to use 6x6 to give porch look of strength, but my neighbor has 8x8 post and I like the look it gives to porch.
My question is what would you go with, 6x6 or 8x8? Again this only for appearance, no HOA, no inspection no nothing. Thanks for help with designing my farm house appearance
pbon
Why wouldn’t you buy what you like, whether 6x6 or 8x8 given that you are doing this for looks and a 4x4 is all you need for structure. Are you just going to box over 4x4 or actually buy the bigger posts?
Earp69
Boxing over would be a whole lot cheaper, that and you can wrap them with steel so you never have to paint them.
  • Like
Reactions: RPH
Garcky
Twin Cities Metro Area, Minnesota
If you like the 8x8 look, then why not go for that? Or, just box in the existing post for a similar look. It's your place, so do what you want.
duneslider
Riverton, Utah
We boxed in our back patio posts that are 4x4. We boxed them out to about 12x12. In our case they are boxed with 2x and osb and then covered with hardi.
Bert_
NW Iowa
Picture of the porch? Small post are definitely too common, lacks the visual support.
My porch posts are about 10" wide from the street side. They are actually 6x6 posts supporting the roof but there is extra lumber scabbed on and trimmed around to make a 8x10
jack stand
Lakes Region Maine
Iirc you used "sawmill" lumber for your framing, a 6x6 or bigger from your sawmill guy shouldn't break the bank.
I'm in full agreement, it's all about proportion, and I don't think a 8x8 would be too big particularly going into a "healthy" beam necessary or not. 👍
kbs2244
do a search for porch post sleeves
they come in all styles and wood, plastic, AL, and steel
atch
Columbia, Missouri
Here's a pic of the porch we built last year. We tore down the smaller porch that had 4x4 posts; shed roof; ugly; etc. The new verticals are 6x6 and the horizontals are 6x10. Douglas fir. Solid. Actual measurement, not "original size before planing". A pic of your porch would help with opinions. In my case 6x6 was the look I wanted. jar944's posts are perfect for his style of house. I believe that my posts match my house. What does your house look like?
mike93lx
Richmond, VA
Go with whatever you like. If I was building, it would be in a craftsman style that uses a large base up to about 42" then tapers to the roof
KenC
oklahoma
My question is what would you go with, 6x6 or 8x8? Again this only for appearance, no HOA, no inspection no nothing. Thanks for1668871609412.png help with designing my farm house appearance
Pick the size that you like. Then, be sure to put a spacer under the bottom to prevent the post from staying wet. Like this: or similar
jar944
Northern VA
I read that as a 42" wide base for the post. I was impressed for a second.
The spacers are code here.
I'd also suggest a pvc or vinyl wrap if it's going to be painted.
nadogail
Coronado, CA
I have seen posts that were cast in semicircles and erected around the existing wooden posts.
I used to get calls to fill in the gaps and cracks with Bondo and apply a coat of paint.
That was about 25 or 30 years ago.
