Rusty Wrench
- Joined
- Aug 19, 2021
- Messages
- 190
I'm finally going to run a water line from the house to my heated shop. About 300'. It will need to enter the shop above grade.
Here is the question I posted to Raychem but it is not going through. The installation guide shows only a single strand along the protected length. Doesn't seem like it should matter but I have a lifetime of "it shouldn't have mattered" consequences.
Is it acceptable to double the heat cable along the pipe?
It is (will be) a vertical Pex pipe coming from up frost depth and entering the sidewall 12" above grade. The Pex would be insulated then sheathed with pvc.
So the temp sensor would be near the top of the Pex pipe above grade (coldest area) and the heat cable run downward to frost depth. Then doubled back up the pipe for the plug to enter the building.
Thank you.
Advice?
Thanks
Thank you.
Advice?
Thanks
