tool_scrounge
Hubbell type twist lock connectors
All are 50 Amp, 250V, single phase, two pole + ground
These are good for plugging in your welder, rotary phase converter, or any other high current 240V single phase application.
These are high grade industrial connectors not to be confused with the plug that your electric clothes drier came with.
They were purchased for a project. Some parts were installed and then removed due to a requirements change.
From the photos:
A & C (B is sold): Hubbell brand CS-8269 ( aka CS8269 ) receptacles. These were purchased new and barely used. You can mount these using a standard 4” square deep electrical box and a Raco 4 In. Square Exposed Work Cover, 30-50A Receptacle (Model # 810C , SKU # 338974, stocked at Home Depot for $2.04 each). You will need to drill two small holes in the work cover (metal front cover) for attaching the Hubbell receptacal.
$22 each + shipping (box & plates not included)
D,F: Marinco brand CS-8265N ( aka CS8265C ) plugs, purchased used but in good condition. $16 each + shipping
E: Hubbell brand CS-8264C (aka CS8264 ) Connector body (also known as in-line plugs). The CS-8265C plugs into it. Purchased new and barely used. $20 + shipping
G: Bryant brand CS-8264N (aka CS8264 ) Connector body (also known as in-line plugs). The CS-8265C plugs into it. New. $18 + shipping
H: Hubbell brand CS-8265C ( aka CS8265C ) plug, Purchased new and barely used. $22 + shipping
J & L (K is sold): Hubbell brand CS-8265C ( aka CS8265C ) plug, New. $23 each + shipping
For more information on the CS-826X series, here is a link to Hubbell’s catalog page:
http://www.hubbellcatalog.com/wiring...s/Page-B56.pdf
Shipping via USPS Priority Mail Flat Rate Box (unless something else is cheaper).
From the photos:
