- Location
- Houston TX
- Price
- Varies
I'm clearing out all of the brand new german tools (Gedore, Stahlwille, Knipex) that I no longer need anymore.
Item 1: GEDORE No.4.8 Flat Ring Wrench Set, 6-22mm Width (8 Pieces) - $125
Item 2: GEDORE 6-8A Double Open Ended Spanner-Set 8 Pcs 1/4-1 - $65
Item 3: GEDORE 4-120 Flat Ring Wrench Set, 6-32mm Width (12 Pieces) - $225
Item 4: GEDORE H 6-12 Double open ended spanner set with holder 12 pcs 6-32 mm - $175
Item 4: GEDORE 1500CT2-7 Check-Tool-Module 2/3 Combination Wrench -$165
Item 5: GEDORE 1815652 1/4" Socket Set, Unit Drive, 4-13mm (17 Pieces) -$185
Item 6: GEDORE 6172450 1/4" Socket Set, 3/16-1/2AF (14 Pieces) - $175
Item 7: GEDORE 6012410 Combination Wrench Set, 8-23mm Width (15 Pieces) - $225
Item 8: GEDORE 20IMU-3 1/4" Socket Set, Hexagon (32 Pieces) - $285
Item 9: GEDORE 6078350 Double Open-Ended Wrench Set, 6-34mm Width (12 Pieces) - $135
Item 10: GEDORE 1743554 Needle Nose Electronic Pliers, 140mm Length - $55
Item 11: GEDORE 6713390 Round Nose Pliers, 140mm Length - $28
Item 12: GEDORE 6727500 Miniature Electronic Side Cutter, 120mm Length - $55
Item 13: GEDORE 6743540 VDE Side Cutter with VDE Dipped Insulation Handles, 140mm Length - $36
Item 14: GEDORE 1743635 Electronic end Cutting Nippers, 135mm Length - $48
Item 15: GEDORE 2178249 1/2" Impact Socket with Protective Sleeve, 22mm - $30
Item 16: GEDORE 6703670 Circlip Pliers for Internal Retaining Rings, Straight, 85-140mm Diameter - $36
Item 17a& b:GEDORE 6702780 Circlip Pliers for External Retaining Rings, Form B, 85-140mm Diameter - $38 each or $70 for both
Item 18: Gedore VDE 146 10 VDE Universal pliers 10" 7-settings adjustable - $65
Item 19:Gedore 145 15 C Water pump pliers 15" 9-settings adjustable - $65
Item 20:GEDORE 1743600 Electronic Mini Diagonal Cutter, 125mm Length - $55
Item 21:GEDORE 1743600 Electronic Mini Diagonal Cutter, 125mm Length - $55
Item 22:GEDORE 6730480 Small Combination Pliers, 125mm Length - $33
Item 23:GEDORE 1429590 VDE Power Side Cutter with VDE Dipped Insulation Handles, 180mm Length - $55
Item 24:GEDORE 6721810 VDE Bent Nose Telephone Pliers with VDE Dipped Insulation Handles, 200mm Length -$48
Payment Method: Paypal (+3%), ChasePay, Zelle, Money Order, Check
Shipping Method: Free Shipping to ConUSA
