rdaleyj
Okay got the low amp probe set at 100 Mv/a
The dso set at 10mv. I tested a few different locations on the feed wire and before clamping the wire the red line on the scope is at zero line, once i clamp the wire the scope trace rises up off the screen and by playing with the zero button on the probe it finally comes down and shows around 2-3 amps 14.6 ms. To be sure enough voltage was getting to the pump i ran a jumper from b+
Straight to pump +. The trace shot off the screen again.
Now im thinking that my probe is shot so i hooked the fp feed wire to my toyota and got a perfect fp wave. 4 amps 9.6ms.no problems with the trace.
All humps are even. So now what could possibly be the problem with the vans fuel pump? Brand new boshe put in last year. Thnx in advance.
