Fun with red thread locker
Mossback70
First off, thanks for all that you guys have put into this site! There's a wealth of info to find. New guy here from the NW working on my first Wilton.
After years of admiration, I pulled the trigger on an old abused Wilton 9450. Bent handle, broken jaw and all threads locked up. In the break down/clean up process I've found 3 bolts that are real stubborn. Looking at some of the others that came out I see traces of red lock-tight. While there is a TON of rust, the lock-tight explains some of my struggle. A couple of these broken bolts I'm going to try welding nuts on. Worst case drilling them out. Not looking forward to that option.
My question, is there a better way that I'm missing? The issues are one jaw bolt on each on each jaw. One flush, one 1/2" exposed. The last one is in one of the swivel lock-downs. Head snapped off so there is a couple inches of thread sticking out of the lock-down.
I've been applying PB Blaster for over a week, tried some heat and some jamb nuts on the lock-down. Doesn't want to budge. I'm thinking more heat but thought to ask the pros . . . . what do you guys think?
Mossback70
Thanks again, right on the money. Once the map gas got her to start glowing it started to let go. The last two are one in each jaw. I was thinking of welding a nut on each. Just not sure if that short weld will heat it up enough. Those jaws are a pretty big heat sink.
yhprum
Brisbane Australia
I have had some luck spraying a solvent like carb or brake cleaner to soften it up. Or you could put the vice on a fire or bbq to cook it good enough to the same effect.
Mossback70
Terra Nova
Map gas will struggle on a big heat sink, but if you're just trying to defeat loctite you only need to get the fastener hot enough to melt the loctite. I would weld the nut on and then hit it with some the map gas to get it hotter and give it a twist.
