Innovate1
Put a condensing furnace (and AC) in my shop building a couple years ago. Perhaps I should have done a minisplit but I got a really good deal on the furnace and I am not changing it now... I keep it at 60 which is very comfortable to me for work there. But it would be nice to lower the temp for long periods when I am not there. I do have some plumbing so need to keep things from freezing (including the traps and such in the furnace). Duct bypassing is typically used for other things like pressure relief in zoned systems but it seems like some bypass air would raise the furnace intake air temp and lower the allowable set point without condensing. I did significant searching but found nothing like this. Am I missing something? I don't have a return air duct - the return is just a filter box and an inlet louver. One place I saw a recommendation that the bypass tap into the return at least 6 feet away to allow some mixing of the air streams and I don't have that. I do have a supply duct running the length of the ceiling so pressure to cause flow in the bypass duct should be fine. It's also two stage but I might just disable the second stage when doing bypass to help. Just starting to think about this and would appreciate any constructive feedback.
