Furnace Filter Search
930dreamer
Amarillo,TX and Stinnett,TX
Rudd 2022 ish furnace, old filter is first picture. Closest new one is second picture and it's too tall. Are these proprietary to the unit?
BrandonV
Arizona
Yup. This is why they list an actual size. You'll find most filters nominal size and actual size are all over the place.
Dagny
Northern Wi.
Oh, everything else is shrinking the cereal boxes are so narrow the ceiling fan blows them over.
930dreamer
These are really close at $48 for a two pack.
Filterbuy 16x20x4 Air Filter MERV 8 Dust Defense (2-Pack), Pleated HVAC AC Furnace Air Filters Replacement (Actual Size: 15.50 x 19.50 x 3.63 Inches)
PCustoms
VT
Height 3.63= 3-5/8 vs 3-3/8 so that should work.
Had a feeling, looks like it's meant to drop in and tuck under the hinge. Anyway to drill the spot-weld off and change the hinge up so you aren't stuck buying 1 brand of filter forever?
bonneyman
Desert SW
Is your filter holder premade, or an old electronic air filter that the cells went bad and you just went to a pleated filter? Can't tell form the pic.
I did quite a few Honeywell electronic filters under the furnace have cells burn out, and replacements were too costly for the customer. So I'd get a 4" pleat and make a slide mount with foam tape to get it to fit tight.
I have found manufacturing tolerances to vary a bit between manufacturers. Even different batches from the same manufacturer. It's hard to get good help these days!
I had my specialty sizes hand-made by a local shop because they were cheaper and more consistent than any major manufacturer. But even then some filter holders were a squeeze of a fit. Many a time I had to do "field alteration" to get a filter to fit.
zendriver
Indiana
As others stated, you need to figure actual size you need
“Nominal” listed size means nothing
They seem proprietary to some extent. I have an add on filter box that only like a certain actual size
BrandonV
Arizona
Additionally, the fit isn't even uniform between filters from the same brand. I've tried three 3M Filtrete filters, and each one had a different fit. One doesn't fit in my return without squeezing it in with a putty knife, another falls down from the return box on the ceiling, and the last one fits like a glove.
Aileron
outside
You may have to do some searching but we had a filter house nearbt that custom make air filters. I had a airhandler 20 ft in the air that they boxed in with ceiling gird hangers. I had them custom make some 4" thick filters instead of two large ones, I used 4 smaller and was able to slide them right in.
930dreamer
The filter came in from the hvac installer, really nice folks. Probably won't get changed until I'm here again. I turned the ac on for the first time since the unit was installed, it's three years old. Mom said it doesn't get warm enough here.....
So far I've fixed the disposal, bathroom sink drain, refrigerator coil cleaned, cleaned all the gutters, worked on the small fish pond, and furnace. Need to order a power antenna mast for the Honda accord. Madness
PoorUB
Fargo, ND
Who made the filter cabinet?
Like the other post, it looks like a Honeywell FC100A1003. The 16" nominal dimension on the Honeywell is almost 16" so check that. The 20" dimension is 19-3/4 so a bit tighter than the one you had.
I see you got one, but was curious, and trying to narrow down something you can buy easily.
bonneyman
Desert SW
A razor knife and hot glue are your friends when it comes to filter alteration. Many times slices made in the right place(s) will allow you to collapse the filter a bit to allow fitment if it's a tad too big. For too small filters some card stock from a stationary store can be added to a side of the filter to make it fit into the frame. For awhile I had to buy standard size pleats and modify them to fit customers aftermarket filter slots to keep them happy, till I found a place that could do it for me for reasonable.
