slowTA
I've noticed my gas baseboard furnace clicking without running. I realized it would stop doing this when I turned one of the 2 thermostats off, basement is the one in question here.
I tried new batteries in the thermostat and tightened the screws holding the wires into the thermostat wall plate, at least one of the two screws was loose.
The condition improved a little, now you can hear water flowing through the baseboard and the furnace light for a split second before shutting off again just to try restarting. I replaced the thermostat (but since the wall plate was the same I just popped the new one in place) with no improvement, the screws are still tight.
I would assume there was something up with the furnace itself, but it cycles normally when the other thermostat calls for heat, so go figure. Funny enough googling "furnace cycles on and off" doesn't help in this situation.
Any quick things I could check before calling in a professional?
