xrdad
After much time spent believing a new Mr. Heater would go into my shop, a deal I couldn't pass up came my way and now I'll be attempting to install a used NG furnace in the garage.
I did a search and found that many have gone this route and most seem satisfied with the results. I'm hoping for the same! But, I could use a little help in the planning part.
If any of you with experience could guide me, I'd very much appreciate it.
Here's what I've got and know so far.
It's a York Diamond 80. Supposedly, it ran fine and was only replaced because the owner needed to upgrade to qualify for a rebate on some home renovations.
The serial # is ELJM491816. I couldn't find a tag with model #?
So now I'm trying to figure out how to get an installation manual... without the model #, might not be easy. I'm hoping someone here recognizes the unit or can tell me where to find the # so I can try to find a book.
Or, is a furnace installation somewhat generic?
The ideal plan would be to hang this unit near ceiling height (15' in my case). It is a downdraft model. I've already had the gas line run to the garage for this purpose. I also already cut a 4" hole in the side wall, about 4' below the soffit. The edge of the roof doesn't stick out a whole lot, less then 20" for sure.
The shop is 20x20 and 15' tall, is insulated (doors too). It's still a work in progress, but will be used for general auto repairs for the most part. If I'm painting/woodworking, the doors will be open.
Not sure if this is enough info to start, so just ask and I'll try to find out more.
Thanks!
Thanks!
