Furnace kicks on when tempover set temp
Reit38
Iowa
We have a rheem furnace with a Econet smart thermostat. Currently thermostat is set to 67* and it is showing house is currently *69. Why would the furnace turn on and run. I just started noticing it doing this.
fitter30
Peace Valley,mo
Gas furnace? Model number of stat?
Older bimetel thermostats had a heat anticipator that was set by either amps by gas valve or burner control. This would shut the gas valve off and blower would run to get all the heat out of the heat exchanger. Rhen the blower would shut down and room temp would be at setpoint. Page 31 anticipator if this is your stat. Under setup. When making a change take baby steps. If it set at 0° try -1° let it run few hours before making another change.
PCustoms
VT
is it blowing heat? or just running the fan to circulate the air in the house?
This was my first thought.
My second thought was I'm pretty sure mine starts the fan again a few minutes after the initial burn is done, to get the residual heat out.
fitter30
Peace Valley,mo
If the fan restarts after the burners are off the fan hasn't run long enought the first time. If the fan control is in a box 21/4" x 3" and a round dial inside "do not turn dial" hold dial there are three settings right one move cw just a little 1/16" try that have to give furnace 5 minutes to see if it comes back onafter it shut downs. That dial is mounted to a bimetel spring. Come back on move it another 1/16".
bonneyman
Desert SW
Sounds like the old Honeywell bimetal coil fan/limit switch.
Like this one?
fitter30
Peace Valley,mo
htmdude57
Hudson Valley, New York
I agree with fitter30. There are 2 problems. The temperature of the house is overshooting. And the fan kicks on a second time. As he said, go into the thermostat to the anticipator setting and lower the number. That should cut down on the temperature overshoot. But for the extra fan kicking on, the setting I believe you need to adjust is the pointer on the left. See the diagram. Its marked #1 in this diagram. Move the pointer a little to the left, so the fan will run till the internal temp of the furnace is around 75 degrees. Then the furnace shouldn't kick on for the extra run.
R
Reit38
Iowa
The fireplace will shut off like normal. But inwill notice it running again latter when the temp is above the set temp. We have a wood burning fireplace going most of the time
R
Reit38
Iowa
Tonight I noticed again that the thermostat was reading tempnwas 71 when set temp is set to 69 and the furnace was running
fitter30
Peace Valley,mo
Having a fireplace running with a furnace. Fireplace is adding heat to the house getting picked up from the return air one possibility. Thermostat is showing 71 set at 69 when does it come back on? Made any adjustments like post 3.
