Furnace parts & tools
paulmars
Price
See ad
Im replacing my furnace with heat pump.
Beckett afg f3 burner w\ new nozzle & new pump. Includes 1 or 2 extra never used nozzles and the perfectly working old pump. New pump & nozzle have less then 1 hour use. pumps: a2va-7116 & 7116B.
200$ w/o used pump. 250$ with both pumps.
Bacharach Smoke tester & 2 packs of papers. used about 50 times. 100$.
orbital flare tool bought new in 2022. used about 10-12 times. 50$
Dwyer model # 400-5 most accurate monometer (more accurate then any digital gauge). No carry case. 100$.
ST9103A electronic fan timer. 75$.
R8184 G originally came with burner 75$.
about 40' new never used oil supply line copper tube tubing. Ends capped. 25$. Piping
Gauges, as shown free with all above.
Fuel filter housing w\ 2 parker shut offs. Filter contains new filter & includes several extra new never used filters. Also 2 extra filter housings never used. Housings and filters free with all above. used one with shutoffs cant be shipped. Pickup only.
extra high temp sheet gasket material. free with all above.
ask for more pics.
Buyer pays shipping or pickup in st pete florida.
Burner installed new 2003 in florida. So, not used a lot. Not used at all when I was away at work or sleeping. So burner really dont have a lot of hours on it. I think electrodes are pretty new too. Aslo have extra set of electrodes.
The smoke tester I bought new 10 years ago and only used it to tune this heater. So, it's basically in new condition. I accidentally bought an extra set of true spot test papers.
Dwyer I bought as surplus. It had dried fluid it in. An engineer at Dwyer told me how to clean it out. It has a few cracks in it as purchased, but none breech the fluid area. Both air connectors were totally blocked and Dwyer told me I could just drill them out, as long as gauge is not laid down it is fine. Connectors allow air in either direction but stop fluid from spilling out. Still I bought two new connectors, but never installed them. Uses red fluid is A-101.
ST9103A electronic fan timer, bought new in 2010 because original hit by lightning.
