dfiler2
I have a question for the HVAC guys, and anyone else with an opinion. I am building a shop inside another building. I’ll try to describe what I’m doing and what my concerns are. I have a 40 x 70 steel quonset, this is attached to a brick and block building. It was built in the 40’s as a theater. The front of the building had the entrance and the second floor had the projector room, the rear was the movie theater, it has since been converted to 4 apartments in the front area and the seating area was filled in and had concrete poured. Two large doors were added to the end of the steel building and I have been using it as cold storage. I decided to build a 40 x 28 shop in the back area up against the front brick and block building. I currently have it insulated and heated and am spending this winter getting it finished off inside. My question has to do with the placement of the furnace, there is a full basement in the front apartment area that I have access to from the shop. The floor of the basement is about 4’ lower than the shop and there is an opening between the two about 3’ x 3’ right in the middle, I would like to place the electric furnace in the basement of the apartments and blow the heat into the shop at floor level. I would have a cold air return at each end, again at floor level. The shop will be used for a lot of different things some would be working on a vehicle or two maybe ATV’s and mostly woodworking and restoration. My concern is pulling air from the shop into the apartment building then back into the shop. If everything is sealed well should I be concerned about the possibility of introducing carbon monoxide or other fumes into the basement? I would really like to place it there because it will be quiet and not take up any room in the shop. I currently have the furnace just sitting on the floor near the elec panel. Thanks in advance.
