Strouty
After there where some issues with my oil fired furnace, I replaced the coil, replaced the cad sensor and things seemed to be working for a while, had another issue and I decided to bring in someone that knows more than me. They replaced the controller with a digital unit and it works well, I could be using improper terms, it is on the furnace and it is not the thermostat, that is a nest. Then it doesn’t work well, now two more calls to the furnace repair man and we have been told that it is our electrical, apparently it gets voltage either above or below voltage levels it like and shuts down for a few hours. If we reset it, everything works fine again, sometimes for days, or weeks, then it throws a fit again. I don’t see any wiring that concerns me, nothing was loose, we have had no other issues with anything else in the house. Is there a way to add a component that keeps the power stable? Seems like the controller is too sensitive or there is an intermittent issue. The circuit is not on a GFCI outlet or breaker. Any ideas on how to chase this? I am tired of paying $100 for someone to tell me there is nothing wrong.
