garboui
Ok, currently my service panel is still on the edison socket screw in fuses. This is something that in the future will be upgraded to breakers and a larger service so please dont give this as the answer to my immediate issue.
I have not had a single issue when running various power tools such as circular says and chop saws (even simultaneously off the same cct. What I do have problems with is when I run my welder (Lincoln SP135), its 115V MIG. Previously on breakers I would have the occasional trip when running fully maxed out for current. On fuses I will pop one even on the lowest heat settings when doing thing gauge sheet metal.
So far I have gone through a few of the standard all glass fuses, and since put in one of the little mini breaker guys. The mini breakers still blow after about 20-30 seconds of continuous welding. I am guessing its the spikes from the switching gear in the welder that cause so much heating in the fuses. I picked up a Buss TC series fuse today thats supposed to be made for more inductive loads. I may see how it does if I get to fixing my drill press stand in the next couple days.
Is there any better, right now, solution that someone has for running a welder off a plug fuse CCT? right now welding is pretty much impossible for anything more than the lightest gauge material.
