Future mini split - penetrations through slab?
deepstuff
Newfoundland, Canada
Just pouring slab. I plan a future mini split install. Should I make any penetrations through my slab in preparation for the mini split install?
The typical mini-split installation run straight thru an exterior wall, above grade. It you want to "bury" the pipes in the wall, you need a 2x6 (or even 2x8) wall.
bzinsky
I ran mine through the walls, I wish I didn't. Just makes it difficult if you have to fix it.
Also had no issues running it through 2x4 framing
justinjoyal
Quebec
No problems running lines in a 2x4 wall.
However as it was mentionned it makes fixing things much more complicated.
Gerald O
NC
It's not any more likely that you'll need to fix HVAC lines in your wall than having to fix plumbing or electrical in your wall. Pretty much a non-issue.
Probably more likely you'll damage it if it's not in the wall.
