G73 won't heat past 50F ??
south_paw
Earth
G73 won't heat past 50F ?? T-stat Fried!!!
On Edit: T-stat was fried. See pics below.
Hi All,
Love my G73 Dayton heater but for some reason today when the room temp gets to 50f the heater cycles on and off about every 3 minutes. The dial is turned up to hi. I have had this heater for about 1.5 years. No issues. What gives?
south_paw
Earth
Re: G73 T-Stat burnt up!
So here is why my heater stopped working :shocking::shocking::shocking:
Checkout the burnt wire
I barely touched it and it broke off
If you own a G73 .... check your wires and strongly consider replacing the factory t-stat with a remote t-stat. The factory one is junk!
nehog
Jaffrey, NH
Funny! I had the same thing happen to my heater in the basement machine shop. In my case it totally destroyed the thermostat, and I did end up using an external one to fix mine too.
