kszach
OK... I've been framing my 12x16 gambrel shed. I will have a loft area that hangs over the shed to form a porch. I framed up the loft floor with 2x8s spanning the 12' width. I put 5/8 floor sheathing down. I started to build the Gambrel trusses. Set the first (temporarily) to get a sense of acomplishment for the day.
I'm struggling with how to support those trusses at the end. Do I cut into the floor so that I can put a plywood gusset from the 2x8 to the truss (constructed of 2x4s)? Do I pop a hole 1 1/4" in the floor and put a simpson strong tie strap down to the 2x8? Do I just toenail the truss into the 5/8 flooring? Maybe some sort of strapping along the truss top to the outside of the wall? I had also thought of putting 2x4s in between the truss ends, nailing them down to the blocking in between the 2x8's.. not sure if I have a lot of room in there before I hit the top edge of the truss.
