Gap between slab and wall
info2x
Berkley, MI
Hello all,
Been lurking for a bit now and to get started with the garage that came with my new home. The floor looks like it's made up of 6 slabs with expansion joints in between them. I've noticed on several of the walls a gap has formed allowing me to see the sand underneath. I'd like to seal this up. The gap is probably 1/4" at the widest parts and in some parts tapers to nothing, making backing rod with a sealant on top difficult. What do you guys recommend?
Thanks
I
info2x
Berkley, MI
Thanks for the quick reply.
Slab seems to be about 5" thick at the edge of the slab so unless the sand has migrated up the side meaning I have a thicker slab or they undercut the center I'm going with 5".
Most of the fillers I've found seem to have a max of 1/2" for depth of crack...
hdshinn
Skagit County, WA
... Most of the fillers I've found seem to have a max of 1/2" for depth of crack...
That's primarily due to the physical stress on a sealant joint that's designed to move quite a bit. I personally wouldn't be too concerned about the depth other than the amount of material it will eat up.
But you could simply sweep some sand into the joint to within 1/2" or so of the surface to take the place of backer rod. Then you could use a gun grade sealant which is a lot less mess than trying to pour the joint full. I'd still mask off the floor and perhaps the wall so you could even tool the joint flush & smooth.
No sign of water migration inside I trust.
I
info2x
Berkley, MI
I'd be worried the sand won't move the required amount and I'll end up cracking the slabs. Which upon closer inspection last night appear to be 2 slabs with reliefs cuts to make them look like 6 total slabs.
No moisture issues that I can see.
You can buy 1/4" backer rod. When the joint gets too narrow for that, you probably don't need it anyway.
I didn't see that last time I was that the store, but I guess I'll have to look harder.
