Garage Air Compressor Filters
Hawkins
All:
I am a home weekend warrior and am setting up 1/2 inch Maxline in my garage. Run will likely go 20 ft, then T off and go another 20-30 feet in either direction. I plan to install a filter/dryer/lubricator right after the compressor (I am sure some my say that' s not enough run); however, given my usage, I think it's fine compared to what I have now (nothing).
That being said, what are the best air filter/lubricators/etc. to use that work with Maxline 1/2 inch piping. I am trying to keep it $100 or less. As to the lubricator, most of the tool usage will be grinders/impact wrench & ratchet. I won't be sanding or painting so not concerned about the lubricator.
Thanks!
johninct
I would not use a lubricator because your system will be ruined for painting and I would not want to use lubricated air to blow stuff off or put in my tires. My friend had a body shop and never oiled his air tools because of a fear of contamination and still got good life out of them. I run 125-150 psi off of my 80 gallon 2 stage on all of my air tools and never had a problem.
K'ledgeBldr
Johns Creek, GA
Seems we had this same conversation not to long ago-
H
Hawkins
Fair enough. Agree i can skip the lubricator however I havent seen much in terms of recommendations of actual filters. Is an Air Filter and Dryer the same? Any thoughts on brands, etc.?
racecougar
Missouri
See post #4. No, a filter is not the same as a dryer. As you're not painting or sandblasting, you're probably just after a filter.
Wilkerson is another good brand.
infinkc
K'ledgeBldr
Johns Creek, GA
I use the philosophy that you protect the compressor- everything after that is also.
Use highly rated air intake filters (Solberg). In-line filters and dryers at the point of use along with the regulator. Dryers tend to not do as well when at the compressor- usually due to the air temp (vapor).
H
Hawkins
i am using this regulator:
https://www.amazon.com/gp/product/B00DQJQ71S/?tag=atomicindus08-20
and this filter:
So far no issues, i do have another regulator/filter on one of my drops going to a reel:
They sell them in 1/2 and 3/4, i used the 3/4 on mine since i have the 3/4 kit.
So i was considering the rapidaire filter. Are you indicating you use both? Isnt Rapidair regulator a filter as well?
Thanks!
infinkc
Thanks!
yea, i guess its an overkill, but just running two filters to make sure everything is caught.
tmandell
I have two DV filters and a top ring water separator in my system. I will be adding a third DV filters with activated carbon for oil removal for painting soon. They are kinda spendy, each was about $300 Canadian.
I am quite happy with them, I have particle filtration down to 0.01 micron, and notice no pressure drop across the filters.
Makoto
Houston, Tx
i modified the quiet ones and put a couple dirtbike filters on the thing. its way louder but way more powerful.
