nissan_crawler
Well, this is what I have:
It had the bench when I moved in. My problem is I don't have much storage space as it is, and having the shelf off the ground wastes valuable space, but it's needed to clean under, since the bench is permanent. I also need a welding table, and a cutting table, but don't have room for one.
Here's what I'm thinking:
The last part of the bench will be left (well, probably rebuilt in steel, but more or less permanent on legs) with doors to cover the well equipment.
The other two will be a welding table and a cutting table that will be the same height as the end bench, both on wheels.
The cabinets will be on wheels, but the wheels will be sunk into pockets in the cabinets, so the cabinets are only 1" or so off the ground, for more storage area. They will have work tops on them, so when I slide the welding and cutting tables out to use, I can work on the cabinet tops, too.
The cabinets will probably be steel frame with aluminum sheeting. The doors will be bi-fold so I can get larger items in, but still open them with a vehicle or something in the way.
I'll probably devise a way to lock the tables onto each other, the permanent bench, and the wall when stored.
Since this is a big project, and I want to do it well from the start, I'm open to any suggestions, which is why I'm posting. So, let's hear your ideas.
I also have a tablesaw floating around, I might make it fit under there.
