Garage Breakers- What to buy
bimmer1980
York, PA
Get ready for sticker shock!!! Those breakers are $50 each...
Meanwhile a GFCI outlet is $20.
I only use a GFCI breaker where I cannot put a GFCI outlet easily.... I.e. Outlets for ceiling mounted outlets for a garage door opener, etc...
You'll need to check your local codes. Out here, garages only require GCFi protection. I think bedrooms in New construction might need arc flat as well, but not sure...
mike93lx
Richmond, VA
keep in mind that a single GFCI outlet will also protect other outlets downstream, if you wire it correctly, so you only need one per circuit.
alfredeneuman
Fullerton, CA
....and faceless GFI's (with no receptacles) can be had for lighting circuit receptacles, installed in the same box as the switches. It just takes 1 more space in the switch box.
(Much less cost than a GFI breaker)
T
TractorJeff
Elkhorn, WI
Thanks Wylie and Berry!
I bought only insulation and LED lights that were on sale yesterday, then spent an hour & half getting pn's and prices for electrical items as there is an 11% sale next week. I have a $1300 rebate check, so I needed to generate a list to get over that amount. Will double check the GFCI outlets prices as they appeared to be $34 each? I didn't pull the package off the rack but maybe as Berry stated those were 3 packs?
dscheidt
Question here.
Does the code read for a "garage" or exterior building/shop ? If it's a "garage" but has it's own meter (not sub panel) does it require GFCIs ?
:confused:
Is it a garage, or an accessory building at or below grade intended for storage, workspace, or similar? Then yes, all 15 and 20 120V receptacles require GFCI protection.
The existence of a separate service doesn't change that.
edit:
The code article reads (210.8.A(2) in 2017 NEC):
Garages, and also accessory buildings that have a floor
located at or below grade level not intended as habitable rooms and limited to storage areas, work areas, and areas of similar use
