Garage build with tricky rules
Tonysbuilds
Hi guys, I'm planing out my garage build and trying to make it as functional as possible while staying within the city rules. I live in wisconsin so it is defiantly a cold weather area.
This is going to be my work shop and I would like a two post lift for working on my truck I also do a lot of fabrication. That being said the rules I have to abide by are as follows.
1. 8' walls
2. 7' max garage door
3. 1024 sq. ft. Max.
I was very disappointed about all of these rules but I have no choice but to follow them. That being said I'm starting to leasn towards...
1. A post frame construction building.
2. 32'x32'
3. Some sort of vaulted ceiling. I could put the lift between ceiling joisdts somehow maybe.
4. Instead of a "garage door" maybe have a wall that slides sideways. Not sure how this will work with heat.
Any tips on how to get around these rules would be great. Oh asnd I would love to move out to the country where they don't have rules but that's not an option. Thank you.
wssix99
Chicago, IL
T
Tonysbuilds
Thanks for the reply. The only problem is 7' is so low my truck may have to put small tires on it to get it to fit after after I solid axle swap it, I would like to be able to pull into the garage without changing tires first. This is not a problem yet but could be when I'm done building it, just trying to avoid future issues. 7' just seems so low.
purplezr2
Central MN
There was a thread about RV garage, I feel like I saw a door in there, that looked like a wall, but folded up or some thing like that, I will find it.
